Fuel Injection Cleaning Question
AILGADEM
Just had an oil change and fuel injection cleaning done on my 86.5 Toyota Supra at my local repair shop. The car hasn't had the injectors cleaned in many, many years, and it has 94,600 original miles.
After the work, I drove the car for about 15 minutes, let it sit for 2 hours, then drove it on the highway at about 65 - 75mph for about 30 minutes. Car ran and felt great! As I exited the off-ramp, the check engine light came on, and car wouldn't start. Oil pressure gauge needle won't move. There is no oil leak. Any suggestions?
Feb 24, 2006 at 1:18 AM
PEPPERMRJ
  • 1,158 POSTS
First be sure you have engine oil.
Depending on whether the engine cranks or not is what you need to check. Here are to links from the "first things to check" link located in the blue bar to the left on this page.
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
https://www.2carpros.com/first_things/car_will_not_crank.htm
It would be helpful if you could retrieve the codes indicated by the check engine light.
Good luck and let us know. :)
Feb 26, 2006 at 7:31 AM
