1995 Toyota Supra
109,000 MILES • 6 CYL • 2WD • MANUAL
TRDSUPRA
I have a na supra that has been modified with a single-turbo kit I think the head gasket might be blown, is it possible to replace it with a twin turbo head gasket?
Dec 21, 2007 at 4:36 PM
  • 31,937 POSTS
The head gasket should be the same, maybe a slightly different material for the extra heat and load, the thickness should be the same, i can't see any advantage in using this gasket, if it is the only one available it should not be a concern, But it might be a good idea to check part No. & a close visual inspection, as there may be a slight difference in the twin turbo cooling gallery coolant porting etc. Just be careful.
Mark (mhpautos)
Dec 22, 2007 at 12:33 PM
