1994 Toyota Supra stop light
12,400 MILES • 6 CYL • 2WD • AUTOMATIC
KEN_VANG99
my stop light don't work, it does not iluminate when the pedal is press. i was told the stop light switch assey, located behind the brake pedal. i changed but nothing, also i can't shift from the park position. please help.
Sep 6, 2008 at 3:32 PM
  • 31,937 POSTS
Hi there,
Check for power into the switch and out of the switch when pedal depressed, if no power into switch check circuit from the fuse box and check fuse and make sure power is flowing with a test light not just a visual.
Mark (mhpautos)
Sep 6, 2008 at 6:59 PM
