1994 Toyota Supra Knocking problem(very Sad)
1994 TOYOTA SUPRA
70,000 MILES • 6 CYL • 2WD • MANUAL
SUPRATT
I took my car out for a ride as i was heading home. I pulled into the driveway i got out and i hear this knocking noise coming from my engine i shut it off right away. The next day I changed the oil to check if theres any metal shaving in the oil i didn't find any, So i decided to change the oil. After that I started it up it had a really loud knocking sound so I shut it off really quick I was thinkin maybe I should give the oil time to go down and through. So bout 10 min later i started it back up and the knocking was totally gone I had thought i fixed it it idle normal until i gave it alittle gas and the knocking started to come back as the RPM got higher it starts around 2k also you can hear the knock comming out of my exhaust i don't know if they will help. If anyone can please help me i been stressed out and i can't figure out whats the problem i just want to get my car fixed. you can also reach me on my email at twenturbosupra@yahoo.com Thank you for your time!
Feb 7, 2010 at 9:49 PM
  • 31,937 POSTS
Hi there,
get the oil pressure tested with a mechanical gauge, but this is sounding serious, heavy engine knock is usually a bearing problem.
mark (mhpautos)
Feb 7, 2010 at 10:12 PM
SUPRATT
After i get the oil pressure gauge and tested what am i looking for as for results and what is the next step Thank you so much for the help
-SupraTT
Feb 8, 2010 at 8:37 AM
  • 31,937 POSTS
If you have low oil pressure you may be looking at a faulty oil pump. I would need the pressure readings to get an idea as to where to go next.
mark
Feb 8, 2010 at 10:11 AM
SUPRATT
Wow Thanks alot mark! as soon as i get the reading from my oil pressure ill let you know
Feb 8, 2010 at 12:01 PM
SUPRATT
ok mark, What i did was an oil change once again, and this time i added thicker oil 20w50. After i waited 10 min for all the oil to go down i started up my car once again the tickin only lasted like 2 sec then it went away, so i let my car run for like a good 10 min and i shut it off about a minute later i started it up again and this time i didn't hear a single ticking/knocking. I took it out for a drive up and down the street at about between first gear through 2 i hear it come back around 3k rpm then it totally goes away for good. It seems to only appear to start from 1st gear to 2nd before switchin into 3rd about 25k to 3k rpm, but other than that its sounds normal. What do you think?
Feb 10, 2010 at 12:00 AM
  • 31,937 POSTS
Hi there, This could be a sludge problem, draining the oil may have cleared some of it out, a good quality engine flush can also help, and even better drop off the sump and give it a good clean out, but this is a bit involved.
Mark (mhpautos)
Feb 10, 2010 at 7:25 AM
