1993 Toyota Supra high idle
205,000 MILES • 6 CYL • 2WD • MANUAL
93SUPRA
i have a 93 supra. the car was running perfect 3 days ago. i went to crank it up about an hour after drving it home and the idle was realy rough. decided not to drive the car. the next day i cranked it up and now it idles steady at 1800 rpms. drove the car around the block and it is running very rich with a little black smoke. i need some help please!!!! there is no CEL
Oct 9, 2008 at 5:05 AM
MMPRINCE4000
  • 8,548 POSTS
Remove and clean the IAC.
Generally a high idle is a vacuum leak. Check all the vacuum lines for cracks.
They get brittle with age and constant heat cycles, abd can crack very easily.
Nov 16, 2008 at 12:08 AM
