1991 Toyota Supra check engine light
1991 TOYOTA SUPRA
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFROE
Can you tell me how to check the code for a chech engine light for a 1991 toyota supra. All I have been able to findout is you have to put a jumper in a plug and count the check engine light flashes. Is this correct - where is the plug located and what are the codes - what do each type mean? Hope you can help.
Thanks
Jeff
Dec 4, 2008 at 3:09 PM
The check connector is in the engine compartment you jumper Te-1 to E-1 and count off the flashes-
Dec 4, 2008 at 3:22 PM
