1989 Toyota Supra oil leak
1989 TOYOTA SUPRA
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
HIGHT
Oil pan gasket has been replaced. Car still leaking 1 qt of oil approx. every 200 miles. Leaks on concrete from the front middle of the car. Car still running smooth. Where is this leak coming from? If it is the main seal, approx. cost.
Apr 27, 2008 at 6:25 AM
Could be coming from the oil pump, front and rear seal, oil drain plug, valve cover, oil pressure switch-you need to find it in order for us to help.
Apr 27, 2008 at 8:04 AM
