1989 Toyota Supra indicator light
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDBARBOUR
Radiator lamp on left side of dash with picture of radiator,goes on when first turn over engine. goes out after time, as if water level rises and continuity is made,then it may reflash again. Plenty coolant in radiator and in over flow tank. Where is the connection made in engine compartment. Thinking loose connection. or old sensor. Thx Ed
Feb 13, 2008 at 3:48 AM
MERLIN2021
  • 17,250 POSTS
the sending unit for the gauge is on the right front side of the motor.
Feb 13, 2008 at 4:02 AM
