1988 Toyota Supra engine idle
EARL INDIAN
Engine Performance problem
1988 Toyota Supra 6 cyl Two Wheel Drive Automatic
engine idle at 1000 rpm up to 2000 down to 1000 back up to 2000 unstable i changed the oil washed the motor have not been able to correct the idle impossible to drive have drided everything out it has been a month have blown with compress air every hose going in to throttle body no blockage i think
1988 Toyota Supra
Updated this is for Bob & Ken you said to remove the idle air control valve in my repair manual it is called a idle speed control valve (isc)
i hope this is the same thing i did remove it from the vehicle and cleaned it i also tested the throttle position sensor and airflow meter which are in repair manual specs what next
Nov 26, 2008 at 5:16 AM
  • 75,988 POSTS
For a start remove the idle air control valve and clean it out-Test the throttle position sensor and airflow meter using the repair manual specs then comeback with results this is where we start to find this culprit.
Nov 26, 2008 at 7:20 AM
  • 75,988 POSTS
When was the last time you had it tune-up ?
Check the fuel pressure with and w/o the pressure regulator, PCV and EGR valves and vacuum leaks-Test the oxygen sensor and fuel injector/s
Dec 2, 2008 at 4:37 AM
  • 75,988 POSTS
If above checks out could be the idle air control valve itself even if its cleaned out if it continues to surge-
Dec 2, 2008 at 4:48 AM
