1987 Toyota Supra No cranking
110,000 MILES • 6 CYL • 2WD • MANUAL
SUPRAMAN10
I have a 87 Supra with a swapped 1JZGTE 2.5L
twin turbo, five speed. The car has a brand new battery. It first cranked rather weakly, but started and ran fine. After 1 hour highway speed, turned it off at rest stop and it barely cranked and only just started. After 3hrs additional driving, turned off and
wouldn't crank. Battery cable was hot! Fiddled with cable and car cranked normally and started. Now car won't even crank, but makes a low humming with ignition in on position. Took out battery and started my J30 with it, no problem. Can't get the Supra to even crank. Help! Thank you!
Jul 27, 2010 at 10:37 AM
  • 75,988 POSTS
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Jul 27, 2010 at 11:01 AM
SUPRAMAN10
Rasmataz,
Thanks for your suggestions. Any thoughts about the faint humming noise which stays on for as long as I hold the key in the start position? Thank you!!
Jul 28, 2010 at 12:54 AM
  • 75,988 POSTS
If the sound is more like buzzing noise it indicates that the starter overrunning clutch is slipping.
Jul 28, 2010 at 1:27 AM
ISLANDER626
I have the same problem. No cranking but not certain about humming sound. I have to jump start the battery for it crank the engine started. Now carry a portable battery jumping system. Well continue to find out, I pretty much have replaced the starter and alternator. Battery and ignition switch are still good
Oct 1, 2010 at 12:02 PM
