1985 Toyota Supra timing
1985 TOYOTA SUPRA
18,600 MILES • 6 CYL • 2WD • MANUAL
ZRAIDER
everytime i get the timing right at 10 degrees it cuts out. when the timing is off it doesn't cut out and runs fine in that regard
Nov 11, 2009 at 3:18 PM
When you're checking timing are you jumpering Te-1 to E-1 in the check connector
Nov 11, 2009 at 5:18 PM
ZRAIDER
yeah..its weird when the timing is right (10 degrees) it cuts out at 2500 rpms. hen its way off it doesnt cut out..im thinking its the tps?
Nov 12, 2009 at 11:14 AM
