1985 Toyota Supra The windows won't go
1985 TOYOTA SUPRA
130,000 MILES • 6 CYL • 2WD • MANUAL
OLDSCAR
The windows and sunroof won't open on my car. We had to jump it off once, and had a surge, That's when the problem started. I need to know where on this car to look to repair this problem. Any help would be appreciated
Jun 19, 2008 at 9:34 PM
SUPRA85MAN
I did the same thing..
Under the dash on the drivers side there's the fuse box
find the silver fuse with a tiny hole in it. you'll have to use a paper clip as i did it will reset and you should be able to use windows
Mar 8, 2009 at 11:45 AM
