1985 Toyota Supra fuel pump
1985 TOYOTA SUPRA
JAMES PATTERSON
Other Category problem
1985 Toyota Supra Two Wheel Drive Manual 160,00 miles
engine not getting fuel,replaced fuel filter,how can i tell if fuel pump is bad ? does a fuel pump make noise? like clicking or humming mine has none at all. took pump out of tank , hooked wires to pump then to battery. nothing.
Dec 1, 2007 at 7:51 AM
  • 31,937 POSTS
Hi there,
This pump will Humm when in operation, Is the strained still attached, if at all in doubt fit a new pump, but don't dry run it as it will over heat and fail quickly. Check fuel pressure and pressure retention.
Mark (mhpautos)
Dec 1, 2007 at 1:04 PM
