1995 Toyota Starlet
1995 TOYOTA STARLET
95,000 MILES • 4 CYL • FWD • AUTOMATIC
KITTA
  • 5 POSTS
While I am trying to accelarate quickly the engin RPM rises very slowly (unusual delay) at the first timeand slow pickup is there. If I try to accelarate again after full releasing of accelarater padle the engin RPM rises in norma manner and picup is good.What would be the problem/reasons for abow matter?
May 17, 2010 at 7:12 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 17, 2010 at 8:49 AM
