1994 Toyota Starlet Pickup
1994 TOYOTA STARLET
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALI.IMAM
When my car engine tempreture hot that time pickup not increase quickly its delay to increase the normal pickup. Plz sussetion me what can I do. I have checked injector which is ok also use octan booster to my car's fuel tank.
Mar 13, 2010 at 8:20 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 13, 2010 at 8:56 PM
ALI.IMAM
Thank you very much. I will check all the thing u mentioned. Boss One thing i forget to know u. That is when I drive atleast 1 hour and than switch off engine and if try start that time pick delay to increase and if i press accelletor randomly that its goes to full pickup. Plz advice.
Mar 13, 2010 at 9:11 PM
