1982 Toyota Starlet Fires two cylinders only
1982 TOYOTA STARLET
KASTE
Engine Performance problem
1982 Toyota Starlet 4 cyl Two Wheel Drive Manual
It seems that gasoline does not get to the two front cylinders. Could it be sticking intake valves?
updated 3-15-10
The 1982 Toyota Starlet has a carburetor. All 4 spark plugs fire. Thanks
Mar 12, 2010 at 8:28 PM
Is this a carbuerated or an EFI system?? if its an injection system check the injectors on that cylinders-let me know
Mar 12, 2010 at 9:46 PM
Could be the intake valves not opening or a problem with the camshaft lobes on those intake valves being worned out-and also a lifter problem
Mar 15, 2010 at 6:56 PM
