Hello and thanks for the donation!
To remove your vehicle's water pump, perform the following steps..
REMOVAL:
Drain engine coolant
Remove the front passenger wheel
Remove the front passenger fender apron seal
Remove the drive belt
Remove vane pump V belt
Remove the engine moving control rod
Remove the engine mount
Remove the alternator bracket
Remove crankshaft pulley
Remove the timing belt covers
Remove engine mounting bracket
Remove timing belt guide and timing belt
Remove timing belt idler sub-assembly
Remove camshaft timing pulley
Remove the timing belt #3 cover
Remove water pump assembly (4 bolts, 2 nuts)
If you have further questions about this repair just let me know
Jul 23, 2009 at 6:13 AM
