2006 Toyota Solara stripped oil pan
2006 TOYOTA CAMRY SOLARA
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGG COX
I have a stripped oil pan from overtightening the plug. Do you recommend fixing the problem by using a different size or type plug, or replacing the oil pan?
Jul 30, 2010 at 8:20 AM
Do you recommend fixing the problem by using a different size or type plug, or replacing the oil pan? If it can work permanently go for it otherwise replace it with a 2nd hand will do, make sure its in good condition.
Jul 30, 2010 at 8:35 AM
