2004 Toyota Solara Slow turning condenser fans problem
86,000 MILES • 4 CYL • 2WD • AUTOMATIC
PASINI
When I turn on the A/C both condenser fans turn at slow speed. If I remove the coolant temp sensor wire then both fans turn at full speed, but of course that makes the fan turn all the time. There are 3 relays, all works. Also I have checked the resistance on the temp sensor, looks ok.
Please help me to stay "cool".
Thanks
Jul 18, 2009 at 2:54 AM
STEVEW84
  • 673 POSTS
What problem are you trying to solve? A slow moving condensor fan? Are you sure there is a problem?
Jul 18, 2009 at 11:48 AM
PASINI
Steve, thanks for your reply.
I am pretty sure it should be turning at full speed, because the AC does not cool properly, if I get the fans to run at full speed it is chill cool.
Jul 18, 2009 at 3:25 PM
STEVEW84
  • 673 POSTS
how did you get the fan to run at full speed?
Jul 18, 2009 at 3:37 PM
PASINI
If I disconnect the coolant temp sensor plug both fans run at full speed. I think that signal is coming from the ECU to prevent the engine from overheating.
Jul 18, 2009 at 3:52 PM
STEVEW84
  • 673 POSTS
This is true. The PCM reads an open circuit in coolant temp. and then PCM turns both fans on as a fail safe.
Jul 18, 2009 at 3:57 PM
PASINI
Yes Steve, that means the fans controls (relays, connections, fan motors, etc) are working. Could you think of a place why it would run at slow speed?
Jul 20, 2009 at 12:24 AM
STEVEW84
  • 673 POSTS
some condensor fans don't run at a very high speed. A good way to test this is to start the car,turn the A/C on so the condensor fan comes on, and then test to see how much voltage you are getting to the condensor fan. If you are getting battery voltage (about 12.6-13.5) then everything is working normally.
Jul 20, 2009 at 1:56 AM
