2001 Toyota Solara Both low beam headlights out
2001 TOYOTA CAMRY SOLARA
94,000 MILES • 4 CYL • 2WD • MANUAL
JAKENMING
Both our low beam lights went out at the exact same time. Our dash light has been dim for a few months, and we recently replaced the brake lights.
The high beams work, but the high beam signal does not show up (on the dashboard) now.
Can you tell me what this might be?
Thank you
Mar 5, 2010 at 4:10 PM
KHLOW2008
  • 41,814 POSTS
Hi Jakenming,
Thank you for the donation.
Is your vehicle equipped with Daytime Running Lights?
Mar 7, 2010 at 5:35 AM
JAKENMING
Yes, it is.
Mar 7, 2010 at 5:47 AM
KHLOW2008
  • 41,814 POSTS
Check the DRL relay, behind dash, right of steering column.
As both low beams and high beam indicators are not working, the only common item able to caus the problem would be the DRL relay.
Mar 7, 2010 at 7:00 AM
JAKENMING
We actually went ahead and bought two bulbs for the low beam lights, and they seem to be working now. We were thrown off because the indicator light when the high beams were on was not working either.
Once we replaced the two bulbs, it is working again too.
Guess we're good for now.
Thanks.
Also, this is the first time I've used this site. Do I have to do anything for you to get the $5 donation? If so, please let me know. If not, thanks again.
Mar 7, 2010 at 7:47 AM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Glad to know the problem has been fixed.
No, there is nothing further you need to do regarding the donation.
Anytime you have any questions, we will be here for you.
Thank you for using 2carpros and have a great day.
Mar 8, 2010 at 1:33 AM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 18, 2010 at 5:48 AM
