2001 Toyota Solara
2001 TOYOTA CAMRY SOLARA
HEYBUUUD
Engine Performance problem
2001 Toyota Solara 6 cyl Front Wheel Drive Automatic
when you step on the accelerater the car gats up to 25 mph and will hesitate and sputter. This is with the accelerater to the floor.
Jun 11, 2010 at 1:07 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 11, 2010 at 1:08 PM
