2000 Toyota Solara Fuel Gauge
134,000 MILES • 4 CYL • FWD • AUTOMATIC
MABDIUHRMAN
The problem is that the car will go out and turn off at the last quarter line on the fuel gauge. I have seen it happen to my mother twice already. When I first brought the car a year it worked fine until the fuel gauge line hitted the last quarter and showed the refuel light on the dash. I don't know what the problem is but I was wonder if any leads that you guys might know.
Jun 8, 2010 at 8:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
anytime you run the fuel tank below 1/4 tank it is extremely hard on the fuel pump. assuming you have driven the vehicle with 1/4 tank or less several times, the most likely culprit would be a failing fuel pump
Jun 8, 2010 at 9:03 AM
MABDIUHRMAN
ok so changing the fuel pump will fix the issue?
Jun 8, 2010 at 4:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
that is the most likely culprit, yes.
Jun 9, 2010 at 6:14 AM
