Toyota sienna rear brake shoes
BIGJOEMAMMA
I own a 1998 Sienna and the rear brakes squeal. I replace rear shoes in the past on other cars so I thought this was easy. I do not see how to remove the rear drum. There is no star nut and I can not budge the drum off the hub. Can someone tell me how to remove the drum? Thank you. :?:
Sep 8, 2007 at 4:37 AM
BRUNO325
After you remove the wheel, you will see two small holes on the drum near the lug bolts. These are used to back the drum off. I think what you screw into the holes are called jack screws, but not sure... It's a metric bolt that you screw in, and the drums backs off. I personally like this better than the old star nut/ hammer method! Good luck!
Dec 8, 2007 at 8:18 AM
CZOM
[quote:b5e217f3be="bigjoemamma"]I own a 1998 Sienna and the rear brakes squeal. I replace rear shoes in the past on other cars so I thought this was easy. I do not see how to remove the rear drum. There is no star nut and I can not budge the drum off the hub. Can someone tell me how to remove the drum? Thank you. :?:[/quote:b5e217f3be]
How did you proceed? did this work out for you?
Greetings
Carl
I have the same problem!
Jun 13, 2008 at 5:00 AM
