starting a Toyota Sienna
TOYOTA SIENNA
ARIELMVP16
I have a 1999 Toyota Sienna 3.0 Engine i replace the cylinder head and i took out all the fuel and oil after i put back the cylinder head that i got the camshaft on time and the crankshaft on time too i try to star the car it seem it wants to start when i press the acceleration if i take it off it just dosent do anything i check the gas to see if it was getting but is not getting anything could that be the problem? if it is how can i get the fuel up to the engine? is their any way?
Apr 25, 2007 at 3:25 PM
[quote:8e2f138712="Arielmvp16"]I have a 1999 Toyota Sienna 3.0 Engine i replace the cylinder head and i took out all the fuel and oil after i put back the cylinder head that i got the camshaft on time and the crankshaft on time too i try to star the car it seem it wants to start when i press the acceleration if i take it off it just dosent do anything i check the gas to see if it was getting but is not getting anything could that be the problem? if it is how can i get the fuel up to the engine? is their any way?[/quote:8e2f138712]
Turn the key to On position the few fuel pump should come On for a few secs. Do you have this?
BTW did you put the engine on TDC compression stroke before you remove the head.?
Apr 25, 2007 at 8:13 PM
