Fault Log Report on Toyota sienna
190 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TUBHOOR
P0125: Insufficient Coolant Temperature for Closed Loop Fuel Control
P0135: O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0141: O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0155: O2 Sensor Heater Circuit (Bank 2 Sensor 1)
P0500: Vehicle Speed Sensor
P0710: Transmission Fluid Temperature Sensor Circuit
P0773: Shift Solenoid "E" Electrical
Mar 28, 2014 at 4:09 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
Start with the coolant temp too low. Make sure it's actually too cool. Check it with a thermometer. If it's running at the proper temp then the sensor is unplugged, bad, or the wires to it are damaged. If it's really cool then the thermostat is to blame. Running too cool makes the ECM unhappy. Remedy the temp then see what codes return
Mar 28, 2014 at 6:30 PM
