Brake and Warning lights coming on
NWTITAN
I have a 2002 Toyota Sienna V6 with 83500 miles. About a month ago the Brake light started turning on intermitently. Now it is on about 90% of the time along with the Trac Off and VSC lights. They do turn off when the car turns to the left. What do you think it is and how can I fix it?
Nov 5, 2007 at 2:57 PM
MERLIN2021
  • 17,250 POSTS
I think you should check the brakes! As the pads wear, fluid in the master is drawn into the calipers, when enough fluid is displaced, the light turns on!
Nov 5, 2007 at 6:30 PM
