cannot reach top gear (fourth) sometimes, especially after a quick stop?
257,762 MILES • 3.0L • 4WD • AUTOMATIC
PHILLIP NGUYEN
Hello! My Toyota Estima 2002 (A.K.A Toyota Sienna) ODO 257764KM automatic has a problem:
The vehicle will not shift into fourth gear sometimes especially when the vehicle is driven for some time.
When I start the car in the morning to drive, it’s OK to shift to gears 1-2-3-4. When it’s in gear 4th, if I just keep driving (>80km/h) then it’s still there, meanwhile I try O/D button => when I press O/D off I can feel the vibration a bit then RPM goes up (to 4000 at 100kpm), when O/D is on the car goes back to 4th gear normally (even try many times).
But when the car slowdown (down to 10-20km/h) then go up again, it will never get back to 4th gear, but bht only 3th gear (then the switching O/D button can just turn on/off the O/D light without any change of driving the car...). I also try to stop the car, turn off, then turn on the car again, then gears can just move from 1 -> 2 -> 3.
I am trying all the instructions mentioned above to see if any of them works on my car.
*Update 8pm 14/2/2023:
Today I started the car and drove for a highway trip (~200km distance) without any stops (only 2 short times needed to slow down to ~20-30km/h).
The car was perfect for the trip that I drove at 100km/h (sometimes up to 140km/h), I tried O/D off & on some times as well.
But later in the afternoon when I started again, it’s could not reach 4th again…
Many thanks in advance.
Best Regards,
Phillip
Feb 14, 2023 at 9:05 AM
  • 110,248 POSTS
The issue can be the result of several things. By chance, have you tried scanning the can-bus for codes?
CAN stands for controller area network. Basically, the different modules in the vehicle are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them. Here is a link that shows how it's done.
Let me know. This is where I would recommend starting.
Feb 15, 2023 at 10:58 AM
