Brake rotors
KAKIMASU28
I am trying to remove the rotors to have them turned but it has a toothed nut which looks like an inverted torque. I was wondering if anyone knew the size of the tool I need to remove this toothed nut and how to remove them?
Nov 4, 2010 at 1:28 PM
DOCFIXIT
  • 18,828 POSTS
Once the caliper is off there is a bolt hole with threads that will force the rotor off once the bolt is inserted and tightened. Here is a guide to help walk you through the steps with a diagram below to show on your car.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Use a 8mm 1.5 thread should work. This video shows how to remove e stuck drum you can use the same methods
https://youtu.be/UV0kfP17Co0
Nov 5, 2010 at 2:28 AM
JEGAUDETTE
i need help on removing the rear rotor on my toyota sienna
Sep 29, 2019 at 11:46 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi jegaudette, Here are the procedures DISASSEMBLY 1. REMOVE REAR WHEEL 2. SEPARATE REAR DISC BRAKE CALIPER ASSEMBLY LH HINT: Do not disconnect the flexible hose from the brake caliper. 3. REMOVE REAR DISC a.Release the parking brake, and remove the rear disc. HINT:  Align matchmarks on the disc and the axle hub.  If the disc cannot be removed easily, turn the shoe adjuster until the wheel turns freely.
https://images.2carpros.com/forum/automotive_pictures/192750_RearBRakeComp09SiennaFig19_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_RearBRakeComp09SiennaFig18a_1.jpg
If rotor is stuck, use 2 pcs of 8 X 1.25 ( m8 ) bolt to slowly tighten into the red dots in diagram to pull the rotor out. Ensure both bolts are turned in evenly ands avoid excessive force. After installation, the park brake shoes have to be adjusted. ADJUST PARKING BRAKE SHOE CLEARANCE a.Temporarily install the hub nuts. b.Remove the hole plug, and turn the adjuster and expand the shoes until the disc locks. c.Contract the shoe adjuster until the disc can rotate smoothly. Standard: Return 8 notches d.Check that the brake disc rotates smoothly. e.Install the hole plug.
KATIEJO21
I am going to replace my front brakes, but am wondering if anyone knows if there is a locking nut on the rotor that needs to be removed before the rotor can be removed.
Sep 29, 2019 at 11:47 AM (Merged)
RACEFAN966
  • 5,029 POSTS
Non that I am aware off. There may be a spring washer on one or two wheel studs if so simply remove and discard. These where only on to keep the rotor on during assembly.
CBAUDER
how do I collapse the parking brake so I can remove the disc with the internal parking brake drum?
BLUELIGHTNIN6
  • 16,542 POSTS
remove plug from the disc to access the parking brake shoe adjuster
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2242.jpg
BASSWEBER
how do I replace front rotors on 2005 Toyota sienna?
BUDDYCRAIGG
  • 2,262 POSTS
take the caliper off and the rotor should pull straight off the wheel studs. sometimes rust can build up between the rotor and the hub, making it difficult.
MGARCIA
Need to know how to change the front & back brakes. I have changed disc brakes on my maxima. Is there much difference or anything I need to do diffrent as it has ABS?
Thanks in advance.
LARREICH
My disc brakes started grinding at 29,.000 mi and I was told car needed both disc pads and new discs. Is this unusual at 30,000 miles? The newly replaced discs & pads are grinding every time I start the car at first. Should I bring back to service again?
DR.PEP
  • 5 POSTS
That seems short. Mine (2004) lasted till 65K with a laid-back driving style. However, when the pads were replaced, there was visible uneven wear between left and right sides of the brakes; which could have shortened the life of the pads.
The repair shop said that the unevenness was not serious. Replacing the hardware kit and brake fluid should help. If not, the next step would be replacing the brake calipers.
LBC2791
How do I remove the rotor? I removed the tire, brake pads, califer, th.e only thing left is the rotor but it is tight
OBXAUTOMEDIC
  • 3,711 POSTS
Look arounf the lug studs, if they are original rotors most have a retaining Spring on 2 of the Studs.
If no retaining springs look around face of rotor for 2 maybe 3 Philips Head Screws, they will need to be removed in order to remove rotors.
If neither of the above spray around center hub and with hammer strike the face of the rotor in different areas. Make take some good hard strikes to break the rust loose.
AKHAN64
I have 2004 Toyota Sienna front wheel drive, I have the same problem. I cannot remove the old rear rotor from axle. As per the previous discussion I understand, it has a lock. The rotor has a hole and it was covered with rubber cap. I removed the rubber now I could see inside. I checked there are four cog/gear instead rotor. They all on different position makes letter ‘X’ (2, 4, 8 and 10 o’clock).
Can somebody paste picture or video to help me how to un-screw and remove the rotor. I tried a lot, but could not succeed. It is very difficult the insert any screw driver inside the rotor via hole (hole is small). Which type of screw-driver should be used? I don’t think it could be possible with common screw drive. Common screw does not contain same number of teeth as cog has.
DOCFIXIT
  • 18,828 POSTS
If rotor after caliper is removed it pulls off. if drum then maybe nesessary to remove plug in backing plat and use screwdriver to backoff star adjuster
AKHAN64
What is the position of star adjuster when you are facing to drum. Is star teeth facing to you in vertical position like to see car's tire from back or front?
How to search by moving drum? In which position I have to bring drum hole in order to see the star adjuster?
DOCFIXIT
  • 18,828 POSTS
12o,clock
AKHAN64
Thanks dear, it is exactly on 6 O'clock position.
DOCFIXIT
  • 18,828 POSTS
Must have watch on upside down
JANANDDEREK
If rotors have deep grooves in them are they UNsafe to drive on. Just had my front brake pads replaced and was told that rotors needed to be replaced, but when I pushed them on it, they said it wasn't UNsafe, it just might be noisy. AT what point would driving on these rotors be UNsafe and is there any other reason to replace these front brake rotors sooner than later?
Thanks
Sep 29, 2019 at 11:48 AM (Merged)
FAIRRACING31
  • 150 POSTS
Light scratches and shallow grooves are normal after use and won't affect brake operation.
Deep grooves - over 0.015-inch (0.38mm) deep - require disc removal and refinishing or replacement.
In our state AZ, by law auto shop's and auto repair store's are required to hold rotor's from owner's that are bellow minimum thickness for safety.
Here is a guide to help walk you through the job
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
It sounds to me that your brake rotor's are not below minimum thickness. Or they would have said flat out replace them. Why they want to replace them and not resurface them, I don't know. But you should alway's resurface or turn your rotor's whenever you replace your brake's. Resufacing the disc brake rotor's produce a smooth, flat surface that will eliminate brake pedal pulsation and other undesirable symptoms related to questionable disc. (brake noise, uneven pad wear, faster wear on brake pad's.)
Without knowing the thickness of your rotor's I can't say if they need to be replaced. The minimum disc thickness is cast into the hub of your rotor. To check, place a dial indicator at a point about 1/2-inch from outer edge of the disc.Set the indicator to zero and turn disc in place. The indicator reading should not exceed 0.006-inch. If it does the disc should be resurfaced. Or you can take your rotor's to a local parts store like AutoZone and they will do it for you.
Rotor's that are below minimum thickness are unsafe, and should be replaced.
DR.PEP
  • 5 POSTS
Grooves decrease the contact surface area between the pads and the rotor. As a result, the stopping power is reduced. It may be unsafe if you have an aggressive drive style or are in a tight situation.
TECHSUP
Grooves increase contact area. The reason is because if rotor surface has grooves it is 3-dimensional. Contact in the 3rd dimension is what increases contact area.
CARADIODOC
  • 34,413 POSTS
That is absolutely not correct. If the sides of the groove are tapered, then it's true there will be more contact area between the friction surfaces, . . . once the linings have worn down that far. It can take many months or years for that to happen. The bigger issue is even with multiple grooves in the rotor that the linings haven't worn down to match yet, that brake is capable of locking up the wheel causing the tire to skid. What's the advantage in having more contact area between the friction surfaces?
One of the main goals is to have balanced braking side-to-side. The only way to know for sure you've achieved that for your customer is to have two perfectly smooth rotors with no grooves, but that story gets even more involved today. I'll share that wondrous story in a minute. FAIRRACING31 posted a lot of good information about rotor thickness. To add to that for anyone else researching this topic, this is a federal law that all mechanics are very aware of. This also relates to my story later. There are two measurements published for rotors on 99 percent of all cars and light trucks. The first is the "machine-to" spec. If a rotor can be machined to no less than that thickness, it is legal to do so. Often a mechanic will leave a few very light scratches in the completed rotor to avoid having to force the customer to buy a new rotor. We can overlook that because tiny rocks and road dirt are going to cause those scratches to form in the rotors anyway. It can be a judgement call, but those few small scratches don't affect braking power or safety.
The second measurement is called the "discard" spec., and is typically .015" or .030" thinner than the "machine-to" spec. I have memorized a common Chrysler front-wheel-drive rotor from the '90s, so I'll use that for my example. The "machine-to" spec. was .830". As long as it ended up that thick or thicker, it could be reused. Once put back in service, it can be allowed to wear as thin as .815". It is legal to BE .815" thick, but it is not legal to MACHINE it to less than .830". That additional .015" gives the legal rotor room to wear under normal conditions.
In theory it is legal to put a rotor back on if it's, . . . say, . . . .820", if you don't machine it, but no professional would risk his reputation doing that. If the brake is apart because worn pads are being replaced, every brake specialist is going to insist on reassembling it with a smooth rotor surface to match the new pads, and if it's not legal to machine the rotor, he's going to replace it. Reinstalling that rotor in that under-size condition refers more to taking that brake apart to perform some other unrelated service, such as replacing a half-shaft. In that situation, you're simply putting back what was already there and was legal. The pads' friction surfaces are already worn to match any grooves in the rotor, so they're making full contact. If the mechanic observes the rotor looks to be under-size, he would be prudent to measure it, then inform the customer of the need for brake work, but if that work is declined, any future lawsuits where the brakes had a direct impact, it would be the person who did the previous brake work who would be involved. A mechanic and a shop owner normally can't be held responsible for safety-related work the customer refuses to have done. This is where documentation is critical. All reputable shops require their mechanics to document everything on the back of the repair order or enter it into their computer. How much of that ends up on the customers' final invoice varies between shops, but there is a record of it if legal trouble pops up. To add to the misery, we already have a bad reputation of selling unneeded parts and services. A mechanic is just as likely to avoid looking at the brakes so he doesn't have to tell the customer more work is needed. In the short run we avoid looking like we're trying to sell unneeded services, but that is not how it's handled when we have our customers' best interest at heart.
For the story I referred to earlier, cars have changed a lot in the last 20 years. They've become lighter and thanks to softer rubber control arm bushings that wear out frequently, they ride softer than before. This has caused a new type of braking problem to show up with an elusive cause. To start this exciting chapter, let me start by describing what I did on my 1978 Chrysler LeBaron a long time ago. The right front brake started grinding metal-on-metal for the second time. Since I had access to a brake lathe with no one looking over my shoulder, I ended up machining that rotor until it was .125" under the legal limit. That's 1/8th inch and terribly unprofessional, but I was broke, and I figured a smooth surface was better than leaving it unmachined and full of gouges. I drove with that undersized rotor for over ten years and never had a problem, but I knew if the other guy ran a red light and I piled into him, his attorney or insurance investigator would convince a jury that I was partly at fault for the crash because I was less able to avoid it because of that rotor, . . . and they would be right. (The same thing can happen to people with altered ride height, meaning lowered cars and raised trucks. That's a whole 'nother story for another day).
The point is, with a legal rotor on the left and a severely-undersized rotor on the right, there wasn't a single symptom or observation to make that known while driving.
Fast-forward to the late '90s. A coworker had been working on a full-size truck for over a full day trying to solve a severe brake pull to the right. On a test-drive, the truck would stop in a perfectly straight line three times, four times, five times, then, always coming down a steep hill near the end of that test-drive, on the eighth pedal application, with no warning whatsoever, the steering wheel got torn out of our hands and we just about ended up on the sidewalk! Once cooled down for about five minutes, that brake pull was gone again. The clue should have been the previous owner just had a perfectly legitimate brake job done. That is when the problem developed. I only learned of the recent history because the new buyer was an acquaintance who discussed the symptoms with me.
After that coworker worked the whole day trying to solve this, I started working with him to figure out what was overlooked. After another half day of frustration, we decided to switch the wheel bearings, brake rotors, and one-day-old new pads, side-to-side. Now, on that same test-drive, when the pull developed, the truck pulled real hard to the left.
All the steering and suspension parts had been inspected. I had already checked the alignment. The new pads hadn't changed anything the day before. Wheel bearings won't cause this. All that was left were the rotors. When we switched just them back side-to-side, the pull to the right came back! Two new rotors solved the problem. THAT is when we finally wised up and found there was a 32-page service bulletin for this exact problem. It pertained to just the 2500 and 3500 trucks, and mainly those with diesel engines because they're so much heavier. That makes the brakes work harder.
This bulletin covers checking for control arms with softer or harder rubber compound. It has nothing to do with the weight of the truck. All that's important is all eight bushings are the same. This only becomes a problem if you buy one used control arm from a salvage yard, and it has bushings that are different. The bulletin describes four different calipers. There's two different piston diameters and for each one there's standard calipers and low-drag calipers for better fuel mileage. Well, none of these things were changed between when the problem developed and before it developed.
There's a lot more to check, but the secret was found in the last few pages of that 32-page service bulletin. When the rotors are machined, they must end up EXACTLY the same thickness, and with the same speed of cut on the brake lathe. That's why the two new rotors solved the problem. When one rotor is thinner, it heats up faster because there's less material to absorb that heat. During the previous brake job, one rotor had been machined just a little more than the other one, a totally common, acceptable, and non-noteworthy practice, but it was enough to lead to this. At some magic temperature, the coefficient of friction changed to where one brake grabbed harder than the other one, and the pull developed. That's why the pull was never there at first when the brakes were still cold.
GREAT AND WONDROUS STORY, PART 2:
The district representative for our state visits every dealership once a month to meet with car owners with problems the dealer is not able to solve. One month he was driving a lemon-law buyback with that same brake pull problem. GM donates their lemon-law buybacks to schools, then they just wash their hands of the problem. Chrysler stipulates that any such vehicle be repaired, regardless of cost, then it goes to an auction. They use the documentation to develop the service bulletins that help their mechanics. I skipped most of that service bulletin and went right to the rotors. Both were way ticker than the minimum legal thickness, but one was .020" thinner than the other one. I used an on-car lathe to cut the thinner rotor very lightly, then I cut the thicker rotor multiple times until it matched the first one perfectly. Brake pull was solved and the district rep. thought I was a genius. I wasn't about to argue with him because I didn't get called a "genius" very often.
The next month he showed up with another truck with the same brake pull, but this one had only .007" difference in rotor thickness. That's the thickness of two sheets of paper on rotors that are 1 1/4" thick. The reason I shared my story of a rotor on my car that was .125" under the legal limit was to put in perspective why .007" and .020" would never be identified as a contributing factor under normal circumstances.
This time I told the district rep. that I was just following the service bulletin. Darn it; he never brought us another truck for that problem! The first mistake my coworker and I made was to not check for service bulletins. We solved this ourselves over a day and a half. Service bulletins are developed exactly so that's what we DON'T have to resort to.
About the same time, this intermittent brake pull was starting to show up on Fords and Chevys too. Brake system specialists and most other mechanics now automatically check that both rotors are machined to the same thickness, but today we are more likely to just install new rotors. Back in the mid '80s, a simple slide-on rotor for a GM front-wheel-drive car cost around $95.00 to $100.00, so it made sense to try to save the old ones. Today, it is common to find a new rotor for a front-wheel-drive car costs less than 20 bucks. Given you're paying for the mechanics time at the brake lathe, and the cost of cutting bits and other consumables, it is less expensive for the shop and much less expensive for the customer to just pop on a pair of new rotors.
One final word of wisdom refers to those new rotors. Many that are sold by the reputable auto parts chain stores are made in China and will develop a brake pedal pulsation in about three months. The proper repair is to go back to the shop that performed the brake service and let them machine those new rotors. There is nothing wrong with the quality of those rotors. When we make parts out of cast iron, we set them aside for 90 days to "age" before they get their final machining. The Chinese cast 'em, machine 'em, pack 'em, and ship 'em, then they age on your car. Minor warping is very common, and one light cut on the brake lathe solves that permanently. Reputable shops will perform that follow-up service at no charge. It's the people who become angry and insist on new rotors under warranty who are going to have the same problem in another three months.
