2006 Toyota Sienna battery
42,000 MILES • 6 CYL • 4WD • AUTOMATIC
JESSICABARROW
My van wouldnt start this morning but it had power the lights and radio would all come on but when you turned the key it made a knocking sound
Feb 25, 2008 at 6:43 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
Feb 25, 2008 at 7:11 AM
