firing order
RKJACK1
I have a misfire in cylinder six. Can you tell me when looking under the hood where that cylinder is? Is it one of the three closest to the front bumper or is it one of the three closest to the dash board? Thank you for your help.
Nov 23, 2009 at 8:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_220.jpg
Nov 23, 2009 at 1:08 PM
RKJACK1
Thanks for the information bluelightnin6. My van's engine lays to the side. In the image you provided, could I just rotate it to the right for it to have the engine in the front making the front of the engine cylinders being two, four and six?
Thanks again for your help,
Rick
Nov 23, 2009 at 8:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
just follow the "front of engine" arrow in the diagram. you can turn it whichever way the front of your engine is pointing .
Nov 24, 2009 at 4:14 AM
RKJACK1
Thanks again. My engine is a front wheel drive that lays to the side, with three in the front and three in the back. Are the three in the front 2-4-6 with the three in the rear being 1-3-5?
Rick
Nov 24, 2009 at 5:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
which side has your timing belt/chain ? that will be the front of engine so you would just follow arrow in diagram.
Nov 24, 2009 at 5:54 AM
RKJACK1
Great, thanks. I understand now. That clears a lot up for me. I appreciate your patience.
Rick
Nov 24, 2009 at 6:14 AM
