2002 Toyota Sienna Warning light
85,000 MILES • 6 CYL • FWD • AUTOMATIC
TROJANMEDIC
We have lost our owner's manual and there is an unusual warning light coming on. It has two arrows pointing to the center of a circular shape. At the bottom of the shape it is flat. In the very center between the arrow points is a dot.
Any ideas?
May 14, 2009 at 2:06 AM
PACKERBACKER
The warning light is the "low tire pressure warning". First check to make sure tire pressure is to spec on all 4 tires. If all ok, have you had your brakes recently worked on? Tires replaced? Mechanic may have not re-connected sensor.
May 17, 2009 at 2:49 PM
