I have a 2002 Toyota Sienna and sometimes when you start it the engine will die. Anytime you let off the gas pedal the engine will die. I can drive it and it works fine if I use both feet one on the brakes and one on the gas to keep it going. Once I get it on the highway and go to a higher speed it seems to correct it self and works fine after that for a week or two and then it does it again. What do you think causes that?
Nov 10, 2008 at 2:10 AM
