Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Sienna
Electrical
Ignition Switch
Key
2002 Toyota Sienna Ignition Key Lockup
2002 TOYOTA SIENNA
150,000 MILES • V8 • 4WD • AUTOMATIC
PAT MANCOL
MEMBER
1 POST
Ignition key is lock. Key can only turn up to ON part and is lockup. Cannot reach up to START. What do I do to start the engine. Thank you
Oct 1, 2010 at 3:31 PM
KHLOW2008
Experienced Mechanic
Hi Pat Mancol,
Symptom indicates the ignition key cylinder is bad and has to be repaired or replaced.
One way of starting the vehicle is to turn the ignition key to ON and jump the starter relay in underhood junction box.
Oct 2, 2010 at 2:16 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Check engine light
Engine won't start
