Ignition key is lock. Key can only turn up to ON part and is lockup. Cannot reach up to START. What do I do to start the engine. Thank you
Oct 1, 2010 at 10:31 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
KHLOW2008
CAR REPAIR CONTRIBUTOR
Hi Pat Mancol,
Symptom indicates the ignition key cylinder is bad and has to be repaired or replaced.
One way of starting the vehicle is to turn the ignition key to ON and jump the starter relay in underhood junction box.
