how to access the brake light bulb to change burned out bulb?
Jul 6, 2008 at 4:53 AM
BLACKOP555
✓Experienced Mechanic
you will have to unscrew/unbolt the tailight assembly then remove the bulb holder and pull out hte bulb.
Jul 6, 2008 at 1:02 PM
TULLIE
MEMBER
Is there more than one screw/bolt holding the brake light assbly? I have tried to remove the brake light assbly, but it feels like there is another screw/bolt holding the assbly.
Jul 7, 2008 at 3:10 AM
BLACKOP555
try prying them apart, the gasket is probably formed and holding them together.
