2001 Toyota Sienna 2001 toyota sienna rattling noises
2001 TOYOTA SIENNA
SAUCEDO7
Noises problem
2001 Toyota Sienna 6 cyl Front Wheel Drive Automatic
We recently have noticed that when we accelerate there is a rattling noise coming from under the hood. At first we thought it was the serpintine belt making noise but when we opened the hood the noise appears to be from on top of the engine. The noise is getting frequent.
Jun 28, 2009 at 3:55 AM
KHLOW2008
  • 41,814 POSTS
Hi saucedo7,
Thank you for the donation.
Noise from the top of the engine could be due to the valve clearances.
Check oil level and condition.
A loose timing belt would cause the nosie as well.
It is recommended to have the problem checked asap as it can be an expensive repair if oil pressure or timing belt are the cause.
Jun 28, 2009 at 6:10 AM
