Where is low pressure port to add refrigerant
ALIL566
six cylinder two wheel drive automatic 160,000 miles.
How can I locate port to add refrigerant to fix AC cooling as it is not cooling enough? I cannot locate low pressure port. High pressure port is very easy to see. That will be nice if you send me a picture. Thanks in advance.
Ali
Jun 8, 2008 at 2:24 AM
EXSMOGGER
Use a flashlight and shine it on the rear left side near the wheel well. You will see a cap with an 'L'. Also this video will show you how you can find the port on any car
https://youtu.be/ON2dYcmXIAw
Jun 28, 2008 at 8:07 AM
