2000 Toyota Sienna Water Leak
2000 TOYOTA SIENNA
CLUGO05
Air Conditioning problem
2000 Toyota Sienna 6 cyl Front Wheel Drive Automatic 90.000 miles
I found the AC drain house missing and I put a new one . After a month I check The floor and the carpet in the inside of the car was wet. I checked for leaks at the passenger side and no sign of water coming fron underneath the dash. But when I checked the driver side behind the brake pedal leather was all wet and foamy. I' d like to know where is all the water coming from . Thank you
Oct 11, 2010 at 2:39 PM
KHLOW2008
  • 41,814 POSTS
Hi clugo05,
For water leaks, you wuld have to perform test to find out where the leak is coming from.
Flip up the carpet and dry it out as much as possible and note where the water is coming from.
Newspaper is good for drying out the carpet. Leave a few layers between the floor and carpet and let them soak up the water.
Oct 14, 2010 at 8:56 AM
