2000 Toyota Sienna Relpacemant cost vs Fixing
117,000 MILES • 6 CYL • FWD • AUTOMATIC
BUGALITO
We just purchased a 2000 Toyota Sienna from a private party 2 weeks ago. Decided to take it into a Dealer to have a window switch replaced and they identified an internal engine knock, poss connecting rod bearing. They said it was OK to drive the car home (67 miles) and gave me no restrictions on driving it, so I did the speed limit on the Expressway. The car drove fine, including using the cruise control.
When we purchased the vehilce there was a ticking sound under the hood. I asked my husband and he said that was nothing to worry about. The car has a beautiful interior and exterior, and drives beautifully, so needless to say, I am in total shock over this news!
I have scheduled an appointment with a local mechanic to get a second opinion. If he concurs with the dealers diagnosis would it better to have the engine repaired or have the entire engine replaced?
What wouold be reasonable cost estimates for each.
Thanks for your help!
Aug 22, 2010 at 5:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
It will take an experience shop around 6 labor hours to remove and replace the connecting rod bearings on this motor. To remove and replace the entire motor assembly that will take approx. 14 labor hours. It will be much cheaper to have the original motor just repaired. Keep in mind most shops today charge anywhere from $65 to $100 an hour in labor costs.
Aug 22, 2010 at 10:21 AM
BUGALITO
Thanks for the information. Took the car to two local folks who both said the engine wasn't that bad and I could drive for years with it this way. They recommended just changing the oil every 3000 miles or 3 months whichever comes first. Since there is a a lot of sludge in the engine (from former owners not doing PM) they did not recommend it being repaired, nor did they recommend going to the expense of having a new engine put in.
Aug 24, 2010 at 1:52 AM
