2000 Toyota Sienna Hazard & Turn signal lights
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
TJEKS1993
For some reason, the hazard light and turn signals no longer work. I have checked both the fuses; however, both tested fine. I have even replaced them to no avail. What else should I try?
Thanks.
Dec 22, 2008 at 11:04 AM
DOCFIXIT
  • 18,828 POSTS
Check out flasher under left side dash. When you turn blinker on does it light and not blink or NADA
Dec 23, 2008 at 12:15 AM
TJEKS1993
Thanks for your reponse.
There are no lights under the dash when the turn signal is placed in the on position. The lights do not work when the "hazard" lights button is depresed either. We did notice that the light will flash when the remote key is depressed to unlock all the doors.
Thanks for any help you can provide.
Dec 25, 2008 at 10:09 AM
