2000 Toyota Sienna
ANGELITO
Electrical problem
2000 Toyota Sienna 6 cyl Front Wheel Drive Automatic
I would like to know what is the problem the light CHEK came on and the code is i think its P1130 you know what its
May 7, 2008 at 1:36 PM
BLACKOP555
  • 10,386 POSTS
P1130: A/F Sensor Circuit Range/Performance (Bank 1 Sensor 1)
that means the bank 1 sensor 1 air fuel ratio sensor is missreading and it could be due to a dirty MAF sensor, or could be due to a bad bank 1 sensor 1 Air fuel sensor.
i have a feeling its a dirty MAF sensor or a failed one because if it was the o2 sensor it would usually throw a o2 sensor code, vs the a/f code that you got, so clean the MAF and hope for hte best, may be a vaccum leak after the MAF sensor and to the cylinders causing the missread also!
May 7, 2008 at 2:15 PM
