1999 Toyota Sienna Rack and Pinion HOUSING Moving when Stee
191,700 MILES • 6 CYL • FWD • AUTOMATIC
MCM0910
Is the Power Steering Gear HOUSING supposed to move left / right when you turn the steering wheel right / left? If not, what would the problem if the housing is moving when the steering wheel is turned?
Sep 27, 2009 at 4:44 AM
STHRNMAN
hello i just seen your question and thought i could help. i recentely did one on our 98 model if its rack and pinion and its moving while the steering wheel is moving its not supposed to maybe a loose bolt there is 2 bolts that hold it in place. may just need to be tightened and then more than likely you will have to have a wheel alignment. i replaced the whole thing on ours because it was leaking fluid from moving side to side for so long. hope i could help.
Feb 25, 2010 at 11:37 AM
