1999 Toyota Sienna Code P0135
10 GOALS
Computer code P0135
1999 Toyota Sienna 6 cyl Front Wheel Drive Automatic 85k miles
Need help. There is a check engine code P0135. Where is this sensor located in the engine compartment? How easy can it be replaced, DIY? Is this a sensor only bought at the dealer? If not, where online? Thanks!
Jul 4, 2008 at 2:55 AM
MELTILLIS
  • 13 POSTS
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
This is a heater built into the oxygen sensor in the exhaust system. Bank 1 Sensor 1 is located in the exhaust next to the firewall / cab of the vehicle. Make sure vehicle is cold when working on this item the exhaust is extremely hot after the engine has run for just a short time.
Dec 6, 2008 at 3:28 PM
