Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Sienna
Trouble Codes
P Codes (Powertrain)
P0100 - P0199
P0125
1999 Toyota Sienna Check Engine Code P0125
1999 TOYOTA SIENNA
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAYCOFJ
MEMBER
1 POST
How do you repair code p0125 closed loop fuel control insufficent coolant temp?
Aug 12, 2009 at 1:12 PM
Experienced Mechanic
Hi there,
your thermostat may be stuck fully open, check this and if engine temp is ok, check the coolant temp sensor for range.
Mark. (mhpautos)
Aug 12, 2009 at 1:42 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
