1998 Toyota Sienna Starter Motor Replacement
150,000 MILES • 6 CYL • FWD • AUTOMATIC
OOHAAHOO
Can you help me with step-by-step instructions for removal and replacement? Is there an online site where I can get a service manual for this job?
Oct 26, 2010 at 8:58 AM
SATURNTECH9
  • 30,869 POSTS
REMOVAL
1. REMOVE BATTERY AND TRAY
2. (w/ CRUISE CONTROL SYSTEM)
REMOVE CRUISE CONTROL ACTUATOR
1. Disconnect the actuator connector and clamp.
2. Remove the 3 bolts, and disconnect the actuator with the bracket.
3. REMOVE STARTER
1. Disconnect the Aft shift control cable.
2. Disconnect the engine wire.
3. Disconnect the starter connector.
4. Remove the nut, and disconnect the starter wire.
5. Remove the 2 bolts, A/T shift control cable clamp and starter. Torque: 37 N.m (380 kgf.cm, 27 ft.lbf)
INSTALLATION
Installation is in the reverse order of removal.
There you go.
Oct 26, 2010 at 9:33 AM
