if the oil pressure guage stays low all the time, even though there is plenty of oil, what is the most likely problem?
Sep 21, 2010 at 1:13 AM
✓Experienced Mechanic
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch. If abnormal could mean oil pump and/or engine bearing.
Sep 21, 2010 at 2:32 AM
