2003 Toyota Sequoia Check Engine Light
2003 TOYOTA SEQUOIA
122,000 MILES • V8 • 4WD • AUTOMATIC
LINDABLOOMER
This morning I was just driving along and my Check Engine indicator light came on. This has never happened before and I had the oil changed and was about to have it changed again. Could it be a sensor gone bad because I do have lights on like ABS that have been on awhile and I was told that the sensor is going bad or could it be the grade of gasoline I've been using for awhile which is Regular grade and I'd been using Plus grade? Thanks for your assistance! Linda Bloomer
May 14, 2010 at 2:52 AM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
May 15, 2010 at 1:47 PM
