2002 Toyota Sequoia Truck does not turn over when key is tu
17,500 MILES • V8 • 4WD • AUTOMATIC
JAZZ4K
I'm not sure if I have a bad battery or starter. Neither has been replaced since I've owned the car (5 years). I noticed the past month or so that almost every day, the first time I started the truck, my radio stations pre-set had to be re-established. I thought this might be my battery going bad. Now, this morning I turned the key and heard the enging slowly drained to just a clicking noise. Question: Is this a sypmtom of a bad battery or starter?
Dec 18, 2008 at 4:41 AM
WILLIAM OLIVER
  • 25 POSTS
well if the battery is charged 12. volts you may have problem with the starter . or make someone hit the starter while starting the car if work replace the starter ( starter location ) is under the intake . will need to remove the intake assy to remove starter
Apr 3, 2009 at 1:20 PM
