new battery engine stalls after
DANDEBEIKES
Engine Performance problem V8 Two Wheel Drive Automatic 100000 miles
Recent problems with battery being dead and the car not starting, or able to be jumped. So I just bought and installed a new battery. Car starts fine but will not keep an idle and if you let up on the gas the car dies immediately.
I checked the fuses and all okay. Is is something with the security/key system that locks out being able to start and run the vehicle?
It ran Fine until I replaced the battery and now it idles low and dies
Dan
Aug 3, 2009 at 2:56 PM
  • 55,616 POSTS
Anytime you replace the battery the engine can lose its idle learn which can easily be relearned by following this guide.
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
Please run down this guide and report back
Cheers, Ken
Jan 6, 2018 at 11:54 AM
