2001 Toyota Sequoia Stereo CD Removal
BPREECE
Electrical problem
2001 Toyota Sequoia
I am wondering how to pull the stereo out? In the cd exchanger two discs were put in one slot so its stuck. If I can pull stereo I can remove it hopefully. Thanks For any help you may have.
Sep 18, 2010 at 5:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1. Tilt the two center vents up and remove the screw at the top of each opening.
2. Remove the climate controls round knobs by pulling them straight out.
3. Gently start prying the center trim away from the structure behind it. It helps it you start around the climate control section, there are about 6 clips total that are holding git in place. Use a plastic putty knife or something similar - don't get aggressive.
4. Pull the trim facade off.
5. Remove the 4 bolts for the stereo - 1 in each corner.
Sep 18, 2010 at 5:25 AM
